Re: My Winter Upgrades
1 Attachment(s)
As far as the exhaust side goes, it's the smaller of the 2 exhaust wheel options. Here are all the specs I believe it is. I just wrote them asking for verification of it all.
Compressor Wheel: inducer-62mm / exducer-84.6mm / 54 trim Exhaust Wheel: inducer-76.1mm / exducer-66.7mm / 77 trim Exhaust Housing: .70 A/R, T3 inlet, V-Band outlet Compressor map attached below. Also I'll post up a map of a .70 A/R GT35R for comparisons sake. http://www.rbracing-rsr.com/turbo/Tu...5rcompress.gif |
Also I was going to mention that it is oil cooled as well which I really like because of simplicity in the engine bay. Less lines going places = :)
That's a very sweet turbo man :)
Also, are you ceramic coating both the manifold and exhaust housing? |
That's a pretty big exhaust wheel, should make some power.
And yes, I'm having that Form and Function place in St. Paul coat my manifold and exhaust housing. |
Also, just picked up the aluminum from Discount Steel to start building my intake manifold.
Sweet! Keep us posted on your progress on the Manifold.
I will keep you posted on the manifold progress.
I did just pick up my new Fidanza 4.3 clutch from MAP, thanks guys! |
Just received and installed the new CF hood today. I'd have pics but my digi cam is busted, and Derek's ran out of battery.
Also I started on the intake manifold. I have the runners cut, and have begun working on the plenum/runner flange. |
Looking good B. I know we talked a little about your build but after reading this, you were holding out on me ;)
Thanks man. Nah I wasn't holding out, just not trying to toot my horn to you.
Here's the pics of the stuff I got coated from FFP. http://server6.theimagehosting.com/a...hp?album=31608 Happy with how it turned out. Can't put it on yet though because I realised I had no fittings for the oil lines. I want to wait for those fittings before putting this all on. Also since I'm going to Spain here in a week or so, the car probably won't be up and running until this Spring. |
4 Attachment(s)
Update with some pics.
Looking good man.
2 Attachment(s)
The new hood somewhat on.
Oh snap, JDM fiber. Lookin good dude
looks good
you need to get the carbon pop ups also |
That and I need some different rad fans since I had to remove one because the turbo gets in the way.
Shouldn't need too much for fans with that radiator and E85.
That's what I hear. Except I experienced a much different thing from that, while trying to keep my car from overheating all last year.
http://www.dsmstyle.com/forums/showt...ht=running+hot |
| All times are GMT -5. The time now is 01:32 PM. |
