Re: My 95 talon
They weren't crazy expensive for buying new. And your welcome to come over anytime.
Re: My 95 talon
Jim you can help me run my boost-a-pump! I received it today along with n AEM wideband. Thanks alot Andrew.
Re: My 95 talon
Dropped off some stuff @ Primo today. Fuelrail, FPR, and blinged oil cap. Hoping for a blacker engine bay.
Re: My 95 talon
Re: My 95 talon
Lets see some progress!
Re: My 95 talon
I think he is getting it tuned this week.
Re: My 95 talon
Yeah tuning on Tuesday! Just been crazy busy. I'll update when I get back from DB.
Re: My 95 talon
Re: My 95 talon
Looks clean!
Re: My 95 talon
Love the gauge setup!
Re: My 95 talon
Mans been busy! Looking good!
Re: My 95 talon
Also did black dash top/door inserts/and switches. Ill finish filling the area by the shifter once its back from Shane! Im pleased with how the interior turned out, and glad I grabbed matching gauges instead of just buying sending units!
Thanks guys. |
Re: My 95 talon
Good luck tomorrow at DB! let us know how she does!
Re: My 95 talon
Things didn't go as planned. I missed my appt. at DB due to stupid me ordering the wrong NGK br7es, and not the brp7es. Yes theres a diffrence, but i didnt know till I googled it.
So threw in the right plugs, acted a little better but through a p0300 (multiple misfire) and now need to trouble shoot from there. Plans are to Buy new wires a new set of BRP7ES. Then see if that fixes anything. If not Ill check coil and power transistor. I am geting spark and fuel across all 4. So that rules out a little. |
Re: My 95 talon
I think you mean BPR7ES? :)
Re: My 95 talon
That sucks about the plugs!
My old car used to throw that multiple misfire code when I first got it running. I think all I did was check the little "don't check for misfire code" button in dsmlink and it solved all my problems. Maybe something to look at? |
Re: My 95 talon
Scheides as long as the P is in there I'm good. I think the misfire isn't checked in link o look again.
Re: My 95 talon
You get that code with a 6-bolt in a 2G. You just turn it off in Link.
Re: My 95 talon
The difference in those plugs is just how far the tip protrudes into the combustion chamber right? We ran both in a locals car last week and it didn't make a difference. The gap made a bigger difference than the plug did.
Re: My 95 talon
Yea, the BR7ES are typically a nitrous plug. They will foul out easier than normal projected tip plug.
| All times are GMT -5. The time now is 12:35 AM. |
