Re: beaterX project thread
I would do a leakdown test. It won't tell everything, but might help you decide if you are going to pull the head. If the valve seats are compressed, then you might also have worn valve guides, which can cause more oil usage or even cause one of the valve guide seals to get knocked out of place.
I agree with Shane on the leakdown test. At least it gives you something concrete to analyze, I know in our professional lives we have a common consensus that data is king and no smart/intelligent decision can be made without it!
I’m speculating the sparkplug failure event could have messed up a cylinder wall a little, that would be worse case?? |
Well the weather outside is frightful, leakdown/compression numbers are trightful, let it go let it go let it go
Evo leakdown results: 1- 50% air from intake & exhaust 2- 50% air from intake & exhaust 3- 20% no leak at all* 4- 50% air from intake &exhaust Cold compression 110 140 130*110 Walkin in an Evo wonderlaaaaaaaand. :) Dear Santa.... |
Those numbers sadden me |
:( still seemed to make good power for that kind of results if you want to look at the positives
It's a dsm, let r buck :)
mighty putty??
Low compression = Moar boost = No more problem :)
Ouch...
Sucky dude
2jz swap. Found you a whole engine for under 1k !
Time for a valve job.
Time for a valve job, maybe some better valves too? Are the factory X valves SS and do they have bronze guides?
Supertechs are nice ones. They have been solid for me, I have the same ones and those have been through two motors on my car. I don't think quality or durability is the problem, at least with the valves, maybe another weak point?
What springs do you have Murlo?
I was going to do Manley's with my build but for whatever reason the Manley ones for the 4b11 are not "manly" and couldn't support the lift on my cams. edit: sorry for going OT. Scheides what springs do you have again? Maybe that is your issue? I doubt it though. |
I think his are the same as yours; that was my initial hypothesis.
| All times are GMT -5. The time now is 05:07 AM. |
