MitsuStyle
-   Brookdale Mitsubishi (http://www.mitsustyle.com/forums/forumdisplay.php?f=55)
-   -   2g Timing belt (http://www.mitsustyle.com/forums/showthread.php?t=10474)
CornFed2.4 02-25-2006 11:25 AM
2g Timing belt
how much and when could I get in
DSMPARTSGURU 02-27-2006 11:59 AM
Re: 2g Timing belt
In Stock....
$60.78 Plus Tax.....
Cc
Kracka 02-27-2006 12:12 PM
Re: 2g Timing belt
I think this clown may be talking about an actual timing belt job from the way I read it.
CornFed2.4 02-28-2006 11:07 PM
Re: 2g Timing belt
correct
DSMPARTSGURU 03-01-2006 08:20 AM
Re: 2g Timing belt
ok???
do you need us to do the work????
CornFed2.4 03-01-2006 10:24 PM
Re: 2g Timing belt
yes
longemoco 03-21-2006 07:49 PM
Re: 2g Timing belt
Originally Posted by DSMPARTSGURU
ok???
i will need a T belt pretty soon, i'm already on the 120,xxx, how much would you guys charge with parts and everything? and how can i get the 20% off for members that says on your sig. thanks
Nick G 03-22-2006 11:00 AM
Re: 2g Timing belt
With dsm discount just labor is $320.00 and belt is $60.78 + tax. You get 10% off labor.To get the discount let the service dept know you are a dsm member.
EclipseGST 03-22-2006 11:13 AM
Re: 2g Timing belt
You will want more than just the belt. Idler pully, tensioner pully, tensioner, probably a good idea to do the water pump since you are right there. (depends on how much play is in the shaft) If you still have balance shafts, new balance shaft belt and tensioner pully.
