MitsuStyle
-   -   replacing my t-belt, (http://www.mitsustyle.com/forums/showthread.php?t=11409)
longemoco 05-06-2006 09:58 PM
well i decided to start doing my t-belt and im stock on the where i need the tool to remove the belt, anyone knows where to get it?i checked , checker and autozone and they didnt have it,
unreal808 05-07-2006 09:43 AM
Re: replacing my t-belt,
You don't have to use a tool to remove the belt. Just be careful to not let the cam unsparing /spin too fast when you remove the belt.
longemoco 05-08-2006 03:08 PM
i got the belt out and everything now i'm in the part where i have to remove camshaft belt, since i dont have the tool. will it mess up the order in the internals if i turn the sprocket(sp) to remove the belt?i just dint wanna remove the back plate and the sprocket
Goat Blower 05-08-2006 07:21 PM
You can turn the sprockets, just make sure to align them all up again when you put on the belts. There are marks to line up on the crank pulley, oil pump pulley, front bs belt pulley and cam gears. The bs belt pulleys can be on the mark in two different positions, only one of them is correct. It's detailed in any repair manual for these.
longemoco 05-09-2006 09:12 AM
ok thanks. now i think i might as well replace idler pulley t-belt tensioner, i just put a brand new water pump, what else should i replace?
