MitsuStyle
-   Want to buy (http://www.mitsustyle.com/forums/forumdisplay.php?f=80)
-   -   Parts needed ASAP (http://www.mitsustyle.com/forums/showthread.php?t=17883)
asshanson 12-11-2007 10:34 PM
Parts needed ASAP
I need these as soon as possible, so I can get my car running and back up to the twin cities.
1. Harness/wires for a 1g Cam Angle Sensor, it's rectangular and has four prongs I believe, it's the black one (hall effect) if that matters. I have the CAS itself, but nothing to plug it into on my 2g.
2. Banjo bolt and fitting to connect the turbo oil feed line on the head to my stainless line with (-4?) AN fitting (the $20 line from SBR). I originally bought the line to go to the filter housing, and it came with a banjo bolt that is a couple millimeters too wide to fit into the head.
SBR_240sx 12-13-2007 05:18 PM
Re: Parts needed ASAP
I dont know if this will help any but here are the part #'s that you need.
MF 650102 - This is the OEM banjo bolt. 12MM
Goodridge 776-04-M12P - This is the adaptor that tapers to the -4 AN line
asshanson 12-13-2007 05:23 PM
Thanks, I just ended up ordering the SBR kit for the oil feed line kit from the head since I couldn't find just the bolt and fitting in time.
User Name 12-13-2007 05:38 PM
I found 3 last night in my box...But I'm so far away shipping would suck just for a bolt.
