Back at it again...
Not sure what I am thinking, but I bought another dsm. The road course stuff has got me interested in possibly joining a club (SCCA or NASA) and I bought a 95 AWD talon to use for my car. I was originally thinking about building a V8 rx7 or 240sx, but determined it would be better to use a car that I have experience messing with instead. The car is 100% stock but has some miles on it. It runs well though.
I will be gutting the car to the bare minimum, installing a cage, changing the suspension, throwing in a 6 bolt and setting up the car for around 300-350whp. I don't expect the project to move very quickly, but it should be fun when it is completed. The car will probably see HPDEs more than anything but I would eventually like to be SCCA or NASA certified. Since I will be modifying the car, I will be required to drive in a higher class so I don't plan on being competitive unless I get at least a few years in. I don't have any pics with me (out of town for work) but will post some up when I get back. |
Re: Back at it again...
Hahaha, as you guys are selling them all, go buy another one. Do DSMers ever really let go?
If anyone knows of any good places to buy roll cages or some good wire tuck threads, LMK. I still need to do a bit of research in those areas. |
Haha back into DSM's....again! Let me know whenever you need a hand on the car if you plan on working on it in Isanti, I'll be out there quite a bit to work on mine the next couple months.
IF u can use E85 I think a 16ghta would be mint.
Good luck with the project |
This sounds fun!
I am not set on making big power, but I am "thinking" that I would be able to keep something around the size of a 60 trim spooled on the track assuming I am in the right gear. I would rather try it out before paying $700 for the HTA 16g or around the same price for a used 30r. I am pretty sure E85 is ok for club racing as some of the road racers on Tuners use it but I am not 100% sure yet.
Goodhart- The car will probably be kept in Isanti for the most part. |
Good luck! John (pushit) i believe is doing cages for a decent price.
My bad I didn't read that u already had the 60, As i have never road raced before, what kind of power band is suited for that?
You get to use some of the higher gears? I'm not too far out from Isanti I would like to see what kind of car suits this kind of racing. |
It is good that the DSM is being put to good use by driving it in SCCA or NASA! I am getting sick of mine just sitting around. I want to put a cage in it and start having fun also!
The 16g has a great powerband for a road race car, but at this time, I am willing to sacrifice a little on the bottom end to be able to pull on the straighter sections. For boost, I want to stay in the lower to mid 20psi range and am not sure I will be happy with the power output of the 16g at that level (maybe I am wrong though). Also, if I decide to do SCCA or NASA, I will likely have one of the slower cars in the class regardless of how good/bad I drive.
The closer tracks, BIR, Road America and MAM all have decent straights so I should be able to generate some speed. In the viper, I was able to get into the 130s on the short course (BIR) and over 150 on the long course. I am sure I could probably do a little better on the long course once I get a little more seat time. I will probably start selling some of my viper parts to put towards this car. I have enough in parts to put down around 800-900whp with the viper, but I don't see any good use for that power. |
I just found a board down here with sick cars a lotta boost vipers etc, and these dudes love their track racing (not drag) Probably bad I just watched underground racing videos too. my vote F DSM, Moar power to VIper and suspension and traction setup. Then run on a low power tune for the track if need be. |
2Gs handle better than 1Gs though right, or take better to mods?
I like your original idea of RX7 or 240 or something that is more pure sports car. |
We are still thinking of setting up one of our cars a little better by adding some of the parts we have though. We might throw the following parts on one of them: -Big brake upgrade -swap to a rear end with bigger gears -Throw the ported heads/aftermarket cam in The ported head/cam swap should get it into the 550-600whp range and the other parts should help somewhat. Any more power than that on the road course would probably be useless. We could turn in the shocks a little (factory ones have adjustable stiffness) but we would probably leave the rest of the suspension stock as it is expensive and the car turns fairly well as it is. We would want to be able to drive the car comfortably on the streets as well. |
A 240 or RX7 probably is a better choice long term, but I don't have the time to really learn either car and have never worked on a V8 before. I have spent a lot of time reading about them but am too busy to go through the swap. Most of the ones that are for sale are also overpriced IMO. I could buy another viper for the price some people put out there... |
ah. makes sense. Good plan you got there. Vipers are awesome, if $$$ ever worked out I would pick one up in a heartbeat for my next project.
Anywho, I hope to make that TX2k10 if my friends down here are still going. PM me some info on used Vipers. please. |
| All times are GMT -5. The time now is 09:44 PM. |
