looking for special tool for timing belt.
I need the special tool to adjust the tension on the timing belt for a 4g63t 6 bolt. Unless some one knows a differnt way. My timing belt was loose and it jumped a tooth.
Re: looking for special tool for timing belt.
U can use a threaded battery tie down rod.
vfaq.com is your friend. |
Which tool are you looking for? The long threaded rod or the tool to rotate the tensioner pulley? The tool to rotate the tensioner pulley you can get from lisle tools or any tool supplier. If I were closer I'd let you use one of the ones I have. The threaded rod you can make and you can see that on vfaq like stated already.
He needs the tool to rotate the tensioner pulley.
I need the one that rotates the pulley
use a screwdriver to pry up on it. then just make sure the hydro tensioner is within the spec range.
this is what ive used on the past dozen timing belt jobs. works better then a pry bar
and you can shank people with it on the weekends too!!! http://i73.photobucket.com/albums/i2...5/PC190015.jpg |
Twack is the man.
I have all the tools you need. Id be willing to borrow them out. Mike S Has them. You can use them if you bring them back to me.
I use a 90* needle nose pliers when I cant find the tool
I made my own with the help of NWA's aircraft alum and titanum pins
| All times are GMT -5. The time now is 07:40 PM. |
