Were to get a crank turned
Were is a good place to get my crank turned and does any know the cost? or should I get a new crank. The one I have now has rods that have been turned to 50mm and the mains are at 25mm. I need the mains turned. But I can get one that in good shape for $175 that has not been turned at all.
Re: Were to get a crank turned
I would not use any turned parts at all. try to get all oem size parts so you know the likely of the problem happening should be minimal.
I'd get the one that is in good shape. But just for reference, Crankshaft Supply in MPLS is the place to get crank work done.
Looks like I going to get the unturned crank. Now I just need to get some ACL Bearings Race Bearings.
Yeah, Tri-Metal bearings for sure... good luck getting ACL's right now though... I was just ag map and I heard 4-5week wait on 4G63 ones... I've had good luck with Clevite 77's also,
Call john Gosh, he had mine in a day. Though that was like 2 months ago, its still an option. |
| All times are GMT -5. The time now is 11:27 AM. |
