Part Out - 10sec 600hp 1991 Talon AWD
10 Attachment(s)
keep all the questions, requests, etc IN THIS THREAD if possible . Please don't PM me saying you want this and that because it gets very confusing. I'd like to keep as much as possible in this thread. Or if you absolutely need to, you can PM me or call me at 612 384-1425
----------------------------------------------------------------------------------------------------- 3" Vibrant resonator - $40 http://www.mitsustyle.com/photopost/...m/P9070569.JPG Forge BOV (pretty sure I have the spring kit for this as well for various psi setups) - http://mitsustyle.com/forums/attachm...2&d=1233977461 - $95 http://mitsustyle.com/forums/attachm...2&d=1282612067 Universal Coolant Overflow bottle - $15 http://mitsustyle.com/forums/attachm...4&d=1282612091 Greddy white face EGT gauge and probe (appx 6 years old) - $35 http://mitsustyle.com/forums/attachm...8&d=1282015671 Beatrush solid driveshaft bushings, brand new (fits EVO and DSM) - http://www.maperformance.com/beatrus...051pmb-2t.html - $40 - Pending Sale 10" Hayden Fan - few years old - you can see a pic of it laying on the floor in the 3rd picture of the motor above - $10 - Pending Sale Starter - $10 - Pending sale Feel free to make offers if you feel something is priced too high. I feel like I priced it all very competitively, but am willing to listen to offers. ----------------------------------------------------------------------------------------------------- Items that have been sold Eagle/Mahle 2.0L short block originally built by MAP, E85 has kept the piston tops pretty deng clean. Compression was 165 across all 4 before removed (this was with 272's installed), exterior of block was painted black by MAP - Please contact me via phone or pm for more info regarding this - What is pictured is what you will be receiving (minus the knock sensor), which is why I took pics at different angles - $800 - Sold HKS 272's - $275 shipped - Sold 17x8 35 offset Rota Boost rims (bronze) w/ Sumitumo HTR Z3 tires (235/45) - tires are nearly new, lots of tread left - $675 - Sold ETS FMIC 3" thick, about 1 year old, still looks damn near new - $360 shipped - Sold 3" Pypes resonator - $40 - Sold 3" Magnaflow muffler w/ tip - $40 - Sold PLX Wideband - will include a used and brand new sensor - $190 shipped - Sold SW white face Boost gauge 30-0-40 (1 year old) - $45 shipped - Sold Stock 6-bolt flywheel & A/C bracketry - $20 - Sold SS Turbo oil feed line - - Appx 3 years old - $10 - Sold Eibach Sportlines w/ KYB AGX's - $375 - Sold Tial 44mm Wastegate ($300 new) - $210 shipped - Sold SLS T3 Mani - lifetime warranty - $425 - Sold S362 (.70AR t3 V-band out) - Turbo has the normal little bitty shaft play. Will include the push-lock drain line, as well as the drain and feed adapter fittings. Feed line not included - short vid available upon request but please only ask me to send it if you are seriously interested - $625 shipped - Sold Two 10" FAL fans- $35 - Sold Pair 6x9's - $20 - Sold Mishimoto Rad Cap - $15 - Sold Aeromotive AFPR kit from Import Evolution - $120 - Sold Taylor 10mm plug wires - will include a new set of 4 NGK plugs for free with these - $40 - Sold Powder Coated Valve Cover (will also include the upper timing and spark plug covers which have been spray painted to match the VC) - $55 - Sold Golan -6 fuel filter and -6AN nylon braided fuel feed, stock 1G fuel rail with AN fitting attached for feedline, and fittings that allow the Golan to attach to the stock lines (see pics) - $100 - Sold Homemade Mini Battery setup - $100 - Sold CF Hood (w/ CarbonTrix Vent) - $400 - Sold Brand new Napa Front Pass Axle, still in the box - $35 - Sold JMF 1G front bumper replacement thingy - $130 - Sold Brand New OEM Mitsu Plug Wires - $40 - Sold Tubular front crossmember - $150 - Sold JMF Race SMIM - $360 - Sold PTE 1600's - $190 - Sold Two Walbro 255hp pumps - $120 for the whole setup - Sold ARP L19's (used for 1 year) - $150 - Sold ACT2900 PP - The clutch disc was pretty much spent, so just selling the PP. It's used, but could be roughened up and reused - $25 - Sold Dynatek Arc-2 ignition box - Plug n Play harness for a 1G (not sure if it's the same between 1G and 2G) - $300 - Sold 4" CAI - This was custom made by MAP (= expensive), places the MAS in the fender well, fits perfectly with my S362 but may require slight tweaking to line up with your turbo setup. I tried to show how it also has a bracket right before it bends down into the fender well, that bolts to the body which holds it nice and steady - $100 - Sold External Oil Cooler and lines (pushlock) - $120 - Sold CAS - $15 - Sold Interior Seat Swap - $60 EPROM ECU w/ Keydiver chip - $230 Rolling Shell - SOLD locally! w/ - Rear Subframe with Jay Racing Toe Eliminator installed. - 1GNT Throttle Body - 4-Bolt Rear End - Adjustable rear upper control arms - Shifter Bushings - Tinted Tails - Evo8 MAS w/ pigtail and 4" adapter coupler, and KN Filter 3 yrs old w/ MAS adapter flange ($1000 rcvd) DSM 3rd Gen design lifters - appx 5k miles on them - $50 shipped - Sold Cobra front brake kit. This will include calipers, brackets, bolts and washers, black braided 2G lines, and rotors (rotors have some surface rust where the pads don't contact) - $475 shipped - Sold Apexi Turbo Timer w/ harness for 1G - http://www.maperformance.com/apexi-turbo-timer.html - $55 shipped - Sold Stock Coolant Pipe with turbo feel line welded shut by MAP (good for people running oil cooled turbo setups) and used Knock Sensor - $35 shipped - Sold Evo Shift Knob - $22 shipped - Sold 2G Head & 90 Oil Filter Housing. - $381 shipped - Sold Mishimoto Alum Radiator - $150 shipped - Sold Stock oil pan modified with a -AN fitting welded (by MAP) for the oil return & JMF dual chamber catchcan setup - $93 shipped - Sold 2 new OEM driveshaft carrier bearings from the dealer, - $125 shipped - Sold TRE Stage 1.5 tranny w/ 4-spider center diff, - $600 shipped - Sold DSMLink V2 with USB cable (no computer included)- $190 - Sold A/C compressor (has fitting on it for Freeze 12 conversion) - $40 - Sold Alternator in good working condition - $20 - Sold |
Re: Part Out - 10sec 600hp 1991 Talon AWD
10 Attachment(s)
Texted you back. Let me know what your plan is because there are a lot of others already interested in it. But of course I'd prefer to sell locally so let me know what you're thinking.
Also, I'm getting some PM's for stuff. Like I said above, please try and keep it in this thread. It makes it so much easier for me I think. I'm adding some pics as well. Will continue to add pics as I get them. |
Can I get pics of the hood? You wouldn't take payment plans for it would you? :o
I'll take the small battery setup I texted you about. Do you take paypal? If so I can send you money ASAP and pick it up whenever. If not, I can make some plans to pick it up on Wednesday if you are around.
10 Attachment(s)
10 Attachment(s)
I'll get you pics, if you want it I'll just consider it sold and hold it for you. But as far as picking it up Wednesday, I don't think that'll work because I plan to start disassembly next Monday. I'm enjoying the car for the rest of this week like I said in the first post. |
I can also give the guys at Primo some cash when they come pick up my car tomorrow and give them an extra $10 for gas money or whatever if you wanna bring it over there at your convenience, that way they can just hand you the cash. |
10 Attachment(s)
Primo is only 5 minutes from my work. If you want to give them the cash, then sure I can just get the money from them and drop off the battery kit with them, but don't worry about $10 gas money.
I want the oil cooler set up. When are you avaible?
Is the shell getting crushed? There isn't a price for it.
I will take the pressure plate/clutch pending removal/inspection.
I'd be interested in the shocks, springs, wheels, rear control arms, possibly the entire dual walbro setup. I am pondering, but just letting you know I have interest.
Hey Brandon, like I mentioned, I'd like the Taylor wires for sure, and I'll pick up the radiator cap for sure as well(for my cousins 1g, he may want some other stuff, but he'll contact you about that.. screen name Launchhard).
We'll chat about the tranny, if someone comes with cash, sell it, otherwise I'm very interested. Oh, and yes, I think the intercooler may be a good option/fit for your next project(may need a little work on the inlet/outlet, but worth keeping IMO). |
10 Attachment(s)
Pics added of the CF Hood for those asking for pics. Like I tried to mention, the vent needed to be trimmed to fit around my manifold, and near that trimming you can see a slight brown from the heat. But it's nothing really.
And if you don't like the trimming, the vent was boughten from CarbonTrix, and you can just buy a new one for like around $90 and rivet it in. Also added pics of the battery kit. I had the JMF one at first, but it doesn't fit right if you still have A/C. So I made this one myself, and so it fits with A/C. So now some of you are saying you're interested, but now that you've seen the pics, let me know if you are still interested and I'll place you as the pending buyer. FYI, there's 2 people interested in the battery kit, and 2 people interested in the hood. So the sooner you let me know, the better because there's multiple people asking for them. |
4 Attachment(s)
FYI the oil cooler kit will include the cooler, the lines, and the fittings that go into the 90 OFH. But it does NOT include the filter housing. If you want the housing as well, let me know and we can talk. |
I'll be giving Blageo money for the Battery kit tomorrow. You can pick it up at Primo after work tomorrow and drop off the battery any time in the next couple weeks. :D
Edit, I'll give him money for the Golan Fuel filter setup also if that isn't taken. |
OK I've added a bunch more pics. If you don't see your name next to something, that means somehow I missed that you wanted something, or it didn't sound like you were 100% serious yet.
So let me know ASAP if you want something 100%. |
| All times are GMT -5. The time now is 12:49 AM. |
