MitsuStyle
-   The Parking Lot - On & Off Topic (http://www.mitsustyle.com/forums/forumdisplay.php?f=21)
-   -   My talon 1/4 mile pass @ BIR (http://www.mitsustyle.com/forums/showthread.php?t=27794)
Fran05 09-03-2010 12:26 AM
Quest for 11's hasn't ended just yet. One more track day, September 8th. I have couple things I want to change, including a trip to DB to rent some dyno time.
goodhart 09-03-2010 01:06 AM
Re: My talon 1/4 mile pass @ BIR
haha, Looks like some new tires are in order too ;)
I have seen this thing at wed night drags quite a bit the last two years.
What's the mod list?
Fran05 09-03-2010 01:25 AM
Just like it says in the video, pretty much a 16g with some supporting mods. Stock motor, a very mild set of cams... FMIC and such. All boost.
I do need some stickier tires, but I'd rather spin than go through transmissions ;)
santa 09-03-2010 01:28 AM
The trans usually hold up just fine. Its the rear axle's you got to worry about. ;)
awd-drifter 09-03-2010 01:30 AM
isn't spinning through awd more harsh for the trans?? but i like, i like :D :D get some rx7 rims, sticker tires and 11s are there! Love the launch! :)
turbotalon1g 09-03-2010 08:39 AM
Can we get more info on your setup?
i just posted on link. People need to put cities in their location. If you are running some higher boost 27+ you should be moving a bit quicker I'd think.
Matt D. 09-03-2010 08:48 AM
Almost! I'd focus on shifting faster, the 1-2 shift was pretty slow, 2-3 not much better, probably shave off 4 tenths right there.
Tachyon 09-03-2010 09:12 AM
Nice, your 1g bounces as much as mine on the launch :lol:
Fran05 09-04-2010 04:53 PM
Stock, shot suspension will do that. I get those "compliments" quite often, too. One time, I actually lifted front tire on the launch, according to bystanders.
Shifting is somewhat slow due to shot clutch pedal assembly. If I slam the pedal down during quick shifts, it doesn't disengage the clutch right away, so I have to wait. Hence slower shifts.
Launch def. needs to be improved, I think I am gonna try from lower rpms (5k in that video)
I am not sure if I want to go and beat on the car some more to get into 11s, we will see. I still need something to drive this winter :)
