some free stuff come get it its free
i have some intercooler piping
2 1 g heads $20 each one with valves one with out 1 awd down pipe with resonator 2.25 in free 02 housings evo3 PORTED by fp o2 housing $60 thought it was my other one retail on one of these is over $200.00 1 2g o2 housing $5 4 1g 02 housings $5 cams $10 a set or 5 each fwd flywheel $5.00 clutch 5.00 its new act 4 puck race $30 used it for 4000 miles and changed still has lots of life left lots of stuff i need to give away i wont have a place for them id like to sell / give these things away instead of going to the dump found a set of chevy bolt pattern wheel spacers i had im missing one to make a complete set of 4 i have got a lot of pms and txt Please txt me your name off here cause there is a post on cl too im not holding any parts ill be at map tomorrow at noon if you need to meet me somewhere |
Re: some free stuff come get it its free
i allso have a awd trans with a welded diff works but noisy $30.00
how good is the clutch?
EDIT:
x2 on trans |
You have a pm
I PMed you.
the trans is noisy as it winds and has a small crack in the bodom where i put some water weld on it so it holds gear oil i drove it like that for 2 months no issues and no grinding its been apart 4 times gears looked ok no chips or missing teeth 5th synro lock ring is gone it dont pop out of gear some times you cant get reverse that's about it
I pmed you last week about picking some stuff up. Still interested if you can respond and let me know which items are still available.
pics of transmission if possible?
| All times are GMT -5. The time now is 01:52 PM. |
