MitsuStyle
-   Project Talk (http://www.mitsustyle.com/forums/forumdisplay.php?f=5)
-   -   94 Talon DL Turbo swap (http://www.mitsustyle.com/forums/showthread.php?t=29463)
Perkul8r 04-17-2011 04:33 PM
So, I thought I would throw up a project thread for this car too seems as how the galant may just get parked for a while.
The car was originally a 1.8 5 speed car, and some owner down the way swapped in a 4G63t into it. And it was done poorly. I am not sure if they did anything right on this. lol. But it did run surprisingly. Which is hard to believe cause when I pulled the ECU out of it last night, it was marked bad and had burned up chips on the inside.
Anywho, here are some pics of the car.
http://i665.photobucket.com/albums/v...L/IMAG0179.jpg
http://i665.photobucket.com/albums/v...L/IMAG0180.jpg
http://i665.photobucket.com/albums/v...L/IMAG0182.jpg
http://i665.photobucket.com/albums/v...L/IMAG0183.jpg
http://i665.photobucket.com/albums/v...L/IMAG0184.jpg
My current plans are to swap out wiring harness, both engine, and chassis harness in the front. It is pretty hacked up. And I got the replacement stuff for cheap. Might swap in my 6 bolt out of my Galant, and than start from scratch on the Galant. Thats still undecided. If anything, I will be rebuilding the short block in this one, and swapping in all the right mounts.
It seems like alot of work for suck a bla car, but, I like to mess around with things. And parts are more than available for this so it can be done cheap. And hopefully the end result will be a good daily driver, than can be taken back and forth to work and what not while I get the galant torn down and ready to painted and fixed.
Perkul8r 04-18-2011 07:51 PM
Re: 94 Talon DL Turbo swap
Today I pulled the dash and fenders so I can have easy access to all the wiring. I should be pulling the motor out soon. Than gotta decide on what to do. Also gonna be selling some things off the car. Things I wont be using.
http://i665.photobucket.com/albums/v...L/IMAG0218.jpg
http://i665.photobucket.com/albums/v...L/IMAG0217.jpg
http://i665.photobucket.com/albums/v...L/IMAG0216.jpg
