MitsuStyle
-   Tuning/Electrical (http://www.mitsustyle.com/forums/forumdisplay.php?f=90)
-   -   Code p0201 (http://www.mitsustyle.com/forums/showthread.php?t=29726)
CornFed2.4 05-23-2011 10:25 PM
Code p0201
So this popped up the other day and the car won't run right. It a cyl. 1 malfuntion. I dont have ton of time to narrow things down, just looking for a good place to start. Im gonna pull the harness and ecu and check for any open wires or damage to the ecu.
CornFed2.4 05-24-2011 09:22 AM
Re: Code p0201
Ill be looking into it this evening so any suggestions would help.
Goat Blower 05-24-2011 10:41 AM
Re: Code p0201
Spark plug, spark plug wire, coil, transistor, injector. In that order.
1QUICK4 05-24-2011 10:59 AM
Re: Code p0201
Check ignition like Steve said but I've never seen a spark plug set a p0201.
Try swapping injector #1 with another cylinder. If your problem moves it's the injector itself. If it doesn't move locations it is more than likely a wiring issue with the #1 injector circut.
CornFed2.4 05-24-2011 02:02 PM
Re: Code p0201
I'm gonna try to swap injectors wires around and see if the problem follows the wire. As far as the spark plugs go there brand new bpr7es and new wires. I have good spark at all 4 plugs too. So I think I ruled out all the spark related stuff
Thanks BTW.
C3L1CA 05-24-2011 02:36 PM
Re: Code p0201
Did you ever clear the code or dis connect the battery after clicking the check box for dsmlink to not look for mis fires?
CornFed2.4 05-24-2011 03:48 PM
Re: Code p0201
I think I did. I'll redo that first.
justinhill 05-26-2011 01:13 PM
Re: Code p0201
ill be able to bring back the extra power transistor back tomorrow.
CornFed2.4 05-26-2011 11:16 PM
Re: Code p0201
Word, do you still need the radio?
justinhill 05-27-2011 09:47 AM
Re: Code p0201
Yeah. When do you get off of work?
