Few misc parts
Just looking for a few miscellaneous parts for my car:
Drivers door plastic insert that holds the window/door switch. Will buy a gray one or I will buy black if you have both drivers door and passenger door, in good shape. Need the plug for the coolant temp sensor on the thermostat housing, has two wires connected to it. Also looking for the connector for the alternator. Mine no longer snaps in and likes to wiggle itself out of place. Let me know if you have an or all of them! |
Re: Few misc parts
Hey man not even really sure what part numbers but I swapped out my coolant temp sensor with a gm one and I was able to just get a plug at a car parts store. Not sure if u are interested in that or not but brand new parts and easily accessible. I could track the kid down that helped me do it if u are interested.
Re: Few misc parts
You shoulda grabbed the alt connector too! That harness still has one
Re: Few misc parts
Yea I didn't think about it when I was there or else I would have grabbed that too, always happens that way.
Dark2g-They sell oem plugs separate? |
Re: Few misc parts
Re: Few misc parts
Oh ok, I will just locate a mitsu one as there has to be some people with cut up harnesses out there!
Re: Few misc parts
Re: Few misc parts
I just got rid of the ect sensor and pigtail, but if you still need the alt connector it's yours.
Re: Few misc parts
I see they have the coolant connector so I may buy that if no one is able to locate both off of their harness. Mark I may have to take you up on that and just buy that coolant connector as it doesn't seem anyone can find one.
Re: Few misc parts
Anyone have the 2g door inserts? Both if you have black and just the drivers if you have gray, power windows.
Re: Few misc parts
I have a grey drivers door insert for the power windows. Not in the best shape but still functional.
Re: Few misc parts
Hmm I'm looking for a good condition one. I have already went through my entire interior to make it mint so kind of want to keep it that way. My stupid mounting points broke off on the underside.. Ebay doesn't even have any which is shocking.
Re: Few misc parts
I ended up buying the connectors new from a vendor, still looking for the door panel insert piece. It is the part that the window control mounts to. Black or Gray!
| All times are GMT -5. The time now is 10:20 PM. |
