MitsuStyle
-   Brakes / Body / Suspension (http://www.mitsustyle.com/forums/forumdisplay.php?f=92)
-   -   Fiav Removal Questions (http://www.mitsustyle.com/forums/showthread.php?t=3757)
john 07-08-2004 01:05 AM
Is it a bad idea for a car driven in the winter? I read somewhere that you may have to use the gas petal to warm your car up.
Would sheet metal do to block it off (~18 gauge) or should I go with something thinker?
Matt D. 07-08-2004 01:40 AM
http://www.vallotton.com/fiavblockoff.asp
LightningGSX 07-08-2004 06:04 AM
Why would you want to remove it?
Matt D. 07-08-2004 11:22 AM
It's the hot shit these days. All the kids are doing it.
Emcee gsxtc 07-08-2004 01:48 PM
if you only strip out your interior behind the front seats your a ricer, but if you strip out every possible little thing you are a racer.
Besides, Having my car idle up and down and everything else is annoying. A slightly cooler intake temp, and my personal favorite: LESS LINES ALL OVER THE PLACE.
Enes 07-08-2004 01:57 PM
so its all a big difference between an i and an a
-E
A//// Guy 07-08-2004 02:05 PM
If you suspect that your FIAV is junk and your car bounces through the rpms back and forth in startup and at idle your FIAV might be bad and if you block it off your idle will be fine...
The only reason to block it is idle problems after youve eliminated the ISC, EGR and other suspects of Idle surge. I would try and find another TB or FIAV to swap out if you ahve idle problems.
illz 07-08-2004 02:39 PM
you can test if it's the fiav by simply bypassing the tb with the coolant lines without blocking off the fiav. if it's functioning, just keep it, and track down the bad isc/egr/dirty tb or intake manifold air leak
Raptor 07-08-2004 03:34 PM
Of course he may just want to keep from having coolant circulate through the TB. I have had mine bypassed for 2 years and never had a problem in the winter. It also is a good way to eliminate more potential coolant leaks depending on what you do with the old connections. Ask JET about how much those coolant leaks can suck. Sometimes you might even replace a head gasket when you don't have to. :stick:
LightningGSX 07-08-2004 03:39 PM
Originally posted by Emcee gsxtc+Jul 8 2004, 12:48 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Emcee gsxtc @ Jul 8 2004, 12:48 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-LightningGSX@Jul 8 2004, 05:04 AM
Besides, Having my car idle up and down and everything else is annoying. A slightly cooler intake temp, and my personal favorite: LESS LINES ALL OVER THE PLACE. [/b][/quote]
how does removing the fiav lower your intake temp? The coolant circulates around the wax pellet of the fiav only, not the TB.
john 07-08-2004 04:41 PM
Mike is right, I would just rather re-route the coolant lines and not have them near the TB. Would there be a problem with re-routing the lines and not blocking off the FIAV or are they related?
Jana 07-08-2004 05:30 PM
Stupid question, what is FIAV?
MustGoFaster 07-08-2004 06:13 PM
Fast Idle Air Valve.
Raptor 07-08-2004 06:40 PM
Not a problem just to loop the lines and leave the FIAV open. It will work fine.
john 07-08-2004 10:09 PM
Thanks, I will do that in a few minutes ;) .
Super Bleeder!! 07-08-2004 10:33 PM
i block that off and the ISC, to be more specific, the entire lower TB assy.
Jet made me a nice plate out of stainless, holes drilled, that fit perfect for $15. he made cher one too actually
