Ok hopefully my car will be started tomarrow for the first time. And I want to make sure I hooked everything up correctly.
Basically all I need to make sure of is the MBC, and the External Waiste gate. Everything else should be fine. -I run an "Extreme" Manual Boost Controller - (looks and works identical to Elite's) With the knob Facing up" - the bottom line is "T" to the BOV Line - The line that goes out the side is connected to the lower nipple on the External waiste gate is that correct? As for the Waiste Gate: -I leave the top "hole" open and only put 1 nipple in on the side for the MBC Line correct? |
Yes you are correct...
-E |
| All times are GMT -5. The time now is 06:17 PM. |
