MitsuStyle
-   Elite Autosport (http://www.mitsustyle.com/forums/forumdisplay.php?f=20)
-   -   DSMStyle Winter Mitsu Turbo Sale (http://www.mitsustyle.com/forums/showthread.php?t=5602)
Shane@DBPerformance 11-24-2004 03:29 AM
DSM Bolt-On Turbos
CPL-GT3251 - $730
Features a 51mm 52-trim compressor wheel, GT center section, TO4E compressor cover, .63 A/R Mitsu exhaust housing, GT32 exhaust wheel.
Compressor wheel flows 42lb/min.
Internally Gated add $50
CPL50 - $730
Features a 54mm 50-trim compressor wheel, 360 degree race bearing, TO4E compressor cover, .63 A/R Mitsu exhaust housing, 69 or 76 trim T31 exhaust wheel.
Good street/strip turbo for a 2.0l, capable of 450-500whp in the right hands. Try it on a 2.4l for crazy spoolup.
Compressor wheel flows 47-49lb/min.
CPL-GT3255 - $730
Features a 55mm 52-trim compressor wheel, GT center section, TO4E compressor cover, .63 A/R Mitsu exhaust housing, GT32 exhaust wheel.
Compressor wheel flows 52lb/min.
CPL61 - $750
Features a 61mm 56-trim compressor wheel, 360 degree race bearing, TO4E compressor cover, .63 A/R Mitsu exhaust housing, 76 trim T350 exhaust wheel.
Good turbo for the 2.0l guys who don't care as much about spoolup, want to go for 500whp, and wouldn't be seen within 5 miles of an Autocross course. Good street/strip turbo for a 2.4l.
Compressor wheel flows 62-65lb/min.
Add $95 for a TO4S compressor cover.
If you really must, internally gated add $50.
CPL-GT3561 - $800
Features a 61mm 56-trim compressor wheel, GT center section, GT35 exhaust wheel, TO4E compressor cover, .63 A/R Mitsu exhaust housing.
The hot setup. The same ultra efficient 61mm 56-trim compressor wheel found in the CPL61, but with an efficient GT35 exhaust wheel and GT center section as an added bonus.
CPL-GT35R - $1050
Features a 61mm 56-trim compressor wheel, Dual Ball-bearing GT center section, GT35 exhaust wheel, TO4E compressor cover, .63 A/R Mitsu exhaust housing.
Essentially a Mitsu bolt-on version of the famous GT35R turbo.
Add $100 for a TO4S compressor cover
CPL-GT3767 - $840
Features a 67mm 63-trim compressor wheel, GT center section, GT37 exhaust wheel, TO4E compressor cover, .63 A/R Mitsu exhaust housing.
Are you trying to make 600+whp? Is your car drag only? Is your revlimiter at least 8500RPMs? Do you like the time that a lot of lag gives you to think about your day? This is the same compressor wheel found on the HKS T04R turbo meant for Supras and big HP. The GT37 exhaust wheel is similar in size to a T4 P-trim exhaust wheel, which is a lot bigger than the small stage 2, 3, 5 exhaust wheels that we are used to on DSMs.
Compressor wheel flows ~75lb/min.
We offer other T04E, T04B and GT turbos. Send me a PM if you are looking for something a else.
Shane@DBPerformance 12-05-2004 02:46 AM
Added more turbos and special price on the 50-trim until the end of December.
