MitsuStyle
-   Brookdale Mitsubishi (http://www.mitsustyle.com/forums/forumdisplay.php?f=55)
-   -   oil pan gasket (http://www.mitsustyle.com/forums/showthread.php?t=8153)
TalonTSI95 07-12-2005 10:25 AM
oil pan gasket
i need a oil pan gasket for a 97 Spyder GST, price and availability, looking to pick it up ASAP
DSMPARTSGURU 07-12-2005 10:28 AM
Re: oil pan gasket
Well unfortunatly I will not be able to help you, since they dont use a gasket. They use silicone. Which can be picked up at any local parts house.
any recomendations form the dsm guru's of the baords for a specific type?
chris
scheides 07-12-2005 10:54 AM
Re: oil pan gasket
the black rtv is what i've always used; it will say 'for oil pans' in the recommended uses on the label.
Tip: use enough, but not too much, and be careful to not scrape any of it off when you re-install the oil pan.
Tip #2: 5 ft-lbs or so on the oil pan bolts--they strip very easily! check your manual.
JET 07-12-2005 11:31 AM
Re: oil pan gasket
Ultra black works great. I have also used Ultra copper because that is all I had, worked fine.
DSMPARTSGURU 07-12-2005 12:10 PM
Re: oil pan gasket
Is ultra copper oil resistant though???? Ive used it on turbo couplings etc... but never for a oil pan.
thanks guys...
chris
niterydr 07-12-2005 12:37 PM
Re: oil pan gasket
Ultra black works great, so would something like hondabond. I've used ultra grey before, but that doesn't work very well imho.
Jakey 07-12-2005 02:20 PM
Re: oil pan gasket
Do not use the blue RTV, even if that is your only choice, use the above mentioned.
niterydr 07-12-2005 02:36 PM
Re: oil pan gasket
LMAO, yeah blue doesn't work as well.
JET 07-12-2005 02:41 PM
Re: oil pan gasket
thanks guys...
chris
Yes, copper is oil resistant. I use it on block/head, most everything on the car.
Enes 07-12-2005 02:48 PM
Re: oil pan gasket
so copper is better than black?
DSMPARTSGURU 07-12-2005 02:50 PM
Re: oil pan gasket
IF COPPER is oil resistance... then it does have a higher temperature rating... so in some ways yes it would be better than the ultra black
cc
JET 07-12-2005 03:21 PM
Re: oil pan gasket
Copper is higher temp, black is stickier and seems to seal a bit better. I think I am using ultra black this time around, it will look better too :D
DSMPARTSGURU 07-13-2005 07:06 AM
Re: oil pan gasket
thanks jet for the clarification.
chris
