MitsuStyle
-   The Parking Lot - On & Off Topic (http://www.mitsustyle.com/forums/forumdisplay.php?f=21)
-   -   did 93 dissapear? why do i only see 92? (http://www.mitsustyle.com/forums/showthread.php?t=8710)
94talonawd 09-03-2005 12:57 PM
hey just wondering... like last year i saw a lot of 93 octane at gas stations when i had my integra.. and now when i just got my tsi, i dont see anymore 93? what the..... do we not have 93 anymore? haahaha
TheBlizzard 09-03-2005 01:05 PM
Re: did 93 dissapear? why do i only see 92?
I think Holiday is one of the only stations that carry 93octane, most are 92.
BP/Amoco 92 is the best pump gas you can get around here in my opinion.
94talonawd 09-03-2005 01:09 PM
what about the non-oxygenated gas that comes from crappy looking gas stations? those are 92. u think these are better or the oxygenated ones from bp/amoco?
TheBlizzard 09-03-2005 01:22 PM
non oxygenated gas is only needed when the vehicle is going to not be used in a regular fashion. It doesn't gel up as much after it sits for awhile, you can use stabil to keep it from geling up as well. If you are going to use the gas right away it doesn't matter if its non oxygenated or not. Just use the BP/Amoco or Holiday 93, don't use SA gas though, or Citgo, ect. Unless you want a knock monster.
Kracka 09-03-2005 05:54 PM
BP/Amoco 92 is by far the best pump gas you can get.
Goat Blower 09-03-2005 09:00 PM
Actually the best pump gas you can get is 100 octane unleaded. 92 is for sissies. :D
Kracka 09-03-2005 09:24 PM
In that case, the 110 leaded would be the best since it too comes from a pump :D
Pimpin Dsmstyle 09-03-2005 09:42 PM
BP in AV has 93 octane :)
Kracka 09-03-2005 09:46 PM
One BP here in Duluth has 93 too.
JET 09-03-2005 11:10 PM
Where the hell did you get that from? Non-oxygenated means non-ethanol. That means you get a little more power out of it because gas has more energy in it than ethanol.
Kracka 09-04-2005 12:28 AM
I think a lot of the non-oxy gas available may be of lower quality though, I did some testing with it back when I had my Talon and I got more knock and lower MPG with it, plus the car just didn't feel as strong.
TheBlizzard 09-04-2005 01:32 AM
I guess I should have worded it better. You should only have to worry about using non oxygenated fuel for older vehicles. Tests have shown that the contents of the oxy fuels can damage older fuels systems. So basically if you are storing your vehicle a lot and not driving it regularly, or if its really old a non oxy fuel would be a better choice. I am not sure if this pertains to DSMs, I would guess not because I have never heard of shit wearing out because of oxy fuels.
Kracka 09-04-2005 02:05 AM
DSM's were designed for up to 10% ethanol content, the non-oxy fuel is primarily intended for collector vehicles, boats, small engines, and other off-highway vehicles.
Shane@DBPerformance 09-04-2005 07:07 PM
You use more ethanol than normal gas, so you get worse gas mileage with ethanol. But since you use more of it, it works out to about a 1% higher power potential from the same amount of gas, even with its low BTUs. So, it's about the same. Methanol on the other hand has even less heat energy that ethanol, but you need to run so much more of it reach stoich that it ends up making 15-20% more power at the same boost level.
