would it be safe for 18psi with fuel pump and stock inj?
ok, so i was reading on dsmtuners and they said it would be safe to run 18 psi with stock injectors and upgraded fuel pump and no fuel management system. would this be ok? or would i need bigger injectors and fuel management system?
Re: would it be safe for 18psi with fuel pump and stock inj?
How are you going to get around boost/fuel cut with 18psi and stock injectors? Do you have a chip?
You may be running too much air and not enough fuel to support. Thats why I'm upgrading to 650 cc inj, AFC2 and a better fuel pump.
I wouldn't turn the boost up anymore until you open up that exhaust also.
I ran 18lbs+with my Laser with the 14b before I had any fuel mods. My MAS was pretty hacked though and it was running on the edge. I found out the hard way a few times when the boost crept when it was colder out and I burnt up a few exhaust valves. I had a full 3" exhaust as well. I would stay in the 16-17lbs range if I were you.
| All times are GMT -5. The time now is 05:52 AM. |
