Old 09-17-2005   #2
Re: Spark Plug Wire installation! gone bad!
From vfaq.com
Spark plug wire routing - if you removed your spark plug wires without paying attention to the routing, don't worry. On 4G63s, the spark plugs are numbered from the timing belt/driver's side - #1 is closest to the timing belt. The connections to the coilpack are 4123, with 4 being closest to the head. See this pic. Note that since 4G63s use a waste spark system that fires 1/4 and 2/3 together, you can also hook the wires to the coilpack as 1423 and 1432 and it will work fine. Note that wire #3 is longer than #4 - shortest to longest, they are 1243.
Hope this helps ya.
