Old 10-06-2005   #2
Re: Dipstick Tube Leaking Oil
You need to unbolt if from the block first. Then it just yanks out, make sure to clean away any dirt from that area first so it doesn't drop into your oil pan.
Also, put a bit of lube on the seal as your putting it on the tube/into the block. That will ensure you don't tear it on install.
-Josh
