Thread: Fuel Cut #2
Old 10-27-2005   #10
Re: Fuel Cut #2
Originally Posted by slowbubblecar
with fuel cut, it will feel like you are going, then jerk (not go anywhere) and keep going again if you keep on it. It would go back and forth if that is the problem. Paintballpro-you don't have fuel cut. It could be the same problem he has, but it feels like a misfire or a really bad tune on your car.
That is it exactly. And I have the instructions for my maf, it is set correctly, and I am not using that for adjusting. Its set for 650cc injectors, 3" gm maf, etc. I was just looking for a way to get around fuel cut, so I could run higher boost. And at first I was trying to confirm that it was fuel cut. The tuning I have done using the AFC isnt that bad, from a dig I can launch the car and go through all the gears fine without that "fuel cut" issue, and it pulls nicely with 0 knock. Also there are no boost leaks.
I'm sorry guys, I am trying to learn here. Please understand that I don't know much yet! Again, thanks for all the input. I guess the boost is gonna stay down, and the car is gonna stay "slow".
