Old 11-20-2005   #1
1Gb rear conversion
Well since the talon is officially parked for the season now, I started removing the rear off of it to convert it over to the 92 style rear end. I had to do a tiny bit of cuttin so far, but now I have it all figured out except one part. The electrical plug on the 92 tails is different then the 91, because there is an additional blinker bulb in the top orange part of the 92 tails that is not in the 91 tails. Has anyone else done this conversion? What did you do to make it work? Here's some pics to help explain my problem.
In the picture, the 92 tail is on the top, and my 91 tail is on the bottom. You can see how the top one has one extra bulb, and that it has a white square plug with four conductor pins, while the 91 tail is rectangle with only 3 pins.
