Old 01-17-2006   #9
Re: ARP Moly Lube - where to buy
Originally Posted by Conquests
i would like to axe if this is a good head pre-lube. i'll be installing valves, cam, rockers, etc. should I use this ARP stuff or maybe a different more specific lube?
No. ARP is more of a assembly lube. You use it with ARP bolts because that is what the torque values "supplied" are made with.
(sometimes when you get a torque spec it is assuming you are using arp moly lube, no lube at all (dry), 30W oil, etc).
There are lubes (like mentioned above) for pre-lubes. This shit would destroy your upper end if used in that form of an application.
