Old 01-17-2006   #1
acidrumz
Send a message via AIM to acidrumz
Re: Calling Minnesota DSMers
some things you can do:
check if you wires are installed correctly.
check or adjust your timing
when your cel is on, extract the code from diagnostic port. you can do with a mutimeter. a pocketlogger would be nice.
check your ecu if it has been re-capped
try those if you can with this bad weather.
gluck
acidrumz is offline   Reply With Quote
