Old 02-01-2006   #8
Re: 1g Non Turbo Piston Questions?
Originally Posted by dumb_ricer
Okay, so what is the oh so great advantage of a Turbo Shortblock over a Non Turbo shortblock besides pistons?
Advantages:
-Turbo friendly pistons (compression ratio, design).
-Oil squirters. They squirt the bottom of the piston to prevent detonation, and on a factory CAST piston, detonation will take your shit out quickly. There are also squirters in the rods to coat your cylinder walls.
-Since I have never ripped apart and checked a N/T block, I wouldn't know, I know that the blocks are very common, but I do not have one here infront of me to point out differences.
You could say oil squirters, which would be valid if you road raced or constantly beat the shit out of the car, but there are a hell of a hell of a lot of other cars with the same power without oil squirters, and hey, they do fine with the same piston to wall clearances that DSM's use.
Its not about tuning. Street cars, or not perfectly tuned vehicles need all the help they can get in keeping shit cool, especially when using a somewhat fragile cast piston. Yes the 4g63 can handle a ton of power with factory components, you hear about it everday. You hear about that one guy that did "xxx" power on "xxx" setup. Do you want to know what I SEE everyday?
Blown motors from people thinking that they can make that same power out of it. (Yes the motors can handle a lot of power, but only in the right hands. You never hear about the failures.) Blown ranges from headgaskets to cracked pistons (ringlands usually), to jumped timing belts, etc.
But oil squirters also have downsides, like lower overall oil pressure in the motor, one more unlikely but potential problem (broken/fallen out).
Yes you have lower oil pressure when they are squirting, but their are ways around that.
I would do it right the first time, but who has really tested the NT shortblock to see just how bad it is? Oh wait, that'd be no one really. Everything I have read has been heresay. I hate when car communities see something different and go "oh noes, thats so bad, you shouldnt do that, joe bob my uncle did it once and it didnt work for him!!!1!!!one111!!, and then suddenly the whole community won't try it because joe bob's broke. The only person who has done it and documented it is doing fine with 330whp, which is more than I plan on making until I do nitrous.
And yes, you are in a community that does things ghetto. And I'm sure EVERY single one of you is guilty of it at some point in the time you have driven cars.
Yes, this community is filled with new members asking stupid questions and doing ghetto stuff. Its called a learning curve. Everyone has done something in one point or another that someone else can consider ghetto, it just depends upon where you are in the "newb" chain. Its not always about following hearsay, but doing stuff that makes sense. If you want to waste your time (which it would be to me, my time is very precious) go right ahead. Go do a write up on it and submit it to Allan. I would be curious as to your results. I can tell you that I have EXTENSIVE research and development, let alone hands on experience, with the 4g63, and I am saying you are wasting your time. There are much better solutions out there.
So who know's if it can handle some power? If it does, I'll be sure to let people know that a NT shortblock handled X power in my case, but I still wouldn't recommend them. In theory with smaller rings, smaller/thinner lands/rings sitting higher in block it *IS* a recipe for disaster, but whats a cracked ring land going to do? Oh no, it burns oil, time to go throw in the now done Turbo Shortblock. A whole nother 150 dollars, damn.
Hmm..cracked ring land? Dead motor. No compression (or low), oil burning, etc.
What happens when it takes out your head as well?
Or shit gets into your oiling system and takes out your new turbo?
Why do things twice?
Oh, and For the record, I'm probably just going to swap the Turbo Pistons/rod's into the NT block and crank and do rings and bearings. I'll be sure to let you know how much more piston skirt scuffing there was in a few months due to lack of squirters.
Go for it, let us know. Best of luck.
