Old 01-22-2004   #17
I said 'rod knock' when you called.
Where are my points for calling it?
allan is right, mitsu is liable for covering it, they already warranteed coverage on the turbo, it is the techs job to check the parts in question, as well as the parts that are in the same system that failed. They should of put 2+2 to realize that when a motor/turbo has no oil the turbo dies as well as....
the motor.
Good luck, just make sure you show proper service records for oil changes and so forth.
