Thread: Engine Troubles
Old 01-22-2004   #24
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Originally posted by ecoli@Jan 22 2004, 01:26 AM
Fuel cut has nothing to do with fuel flow.
You could put in a 1000lph fuel pump and rewire it and it's won't affect fuel cut at all. Putting in bigger injectors or raising the fuel pressure with also not fix fuel cut on their own.
Fuel cut is based purely on the ECU reading to much air flow, it doesn't give a crap about fuel, it has no way to even know if it's running lean at WOT. The ECU is basically just programmed that if it sees over X amount of airflow at X RPM it does fuel cut because it thinks the wastegate has failed. You have to make the ECU see less airflow to keep it from fuel cutting. You can do that by lowering the boost, hacking the MAS, or using an electronic fuel controller to lower the airflow signal Hz getting to the ECU.
Finally some correct info! I don't buy into the gm maft stuff much just because of Peter's eperiences. Having to turn boost down to 13 psi (with the gm maft) so I don't hit fuel cut is pointless IMO.
Get 550's and a SAFC to help with fuel cut. If you don't have much money you can hack the mas a bit. You will need a fuel pump in your setup but it will NOT do shit for fuel cut.
If you get larger injectors, you can remove some of the reading from the MAS with teh SAFC. That is how you get away from fuel cut. I am not sure of the exact number on a 2g mas but you would hit fuel cut if you exceeded the mas' rating of 2100 (guessed on #). If your car is overrunning the mas (say getting 2200) you will get fuel cut. That is why a pump will not help you. You need to take away part of the airflow reading with a SAFC or by hacking the mas.
7/25/09
