Old 09-12-2006   #1
Gravy
Who's this guy?
Compresion Issues, Long Post
I've run into compresion issues on a car. I know most of you will say "Rebuild that shi±!" But, i don't have the time, or the money atm to rebuild, and i'm seeing if i can fix the problem simply.
Symptoms are as follows. About 2 months ago when i first got the car i had 150-150-145-150 compresion. NO issues and the car was ok. Then randomly i get intermitent acceleration issues. Figured i have two studs missing, it's an exauhst leak and i'm sometimes leaking and sometimes not. New gasket and fixed the studs... Notice better spool up from port job, boost spike is fixed and no more creeping. Problem fixed? Thought so.
Five nights ago i give the car a compresion test to check and see what i'm running. First test: 150-152-130-150. Blown ring is my first impresion, i'm pissed and worried as hell i've gota rebuild over the winter. I go to remove the insert and hose from the head and see it's lose. I get a 145 and think, good, everythings still ok. Three nights ago the car starts idling rough and smoking while at idle but not under WOT or even partial throtle. I check the car again: 150-152-135-150 Figure i'll run out the tank of gas, then garage it too check it out and see what needs to be done. The next day on the way to work, idle's fine. No stubling at idle(Idle surge) and no smoke coming from the exauhst at idle, PT or WOT. Checked the compresion and got the following: 150-150-145-150
Today runs fine for about 2-3 hours worth of driving then part way through the day it's like a switch is turned off in the car. Runs like shit. Smoke at idle, rough idle and surging on me like mad. Tonight i check the compresion: 152-150-120-150
From what i've read and heard, with a "Variable" compresion PSI like this it wouldn't be a ring, once it goes bad it's bad. There's no good days and bad days. When i pulled the plugs i shined a light down the holes the last two times when i got the 145 and when i got the 120. When i got 145 PSI the top of the piston looked clean enough to eat off of. When i checked it on the 120 night there was oil drops on the top that i could see.
Sorry for such a long post, but i wanted all the facts in before i expect detailed answers or opinions. My question is, and this has been mentioned before when i was burning oil. Could it be a valve guide seal gone bad?
I pulled the manifold off tonight to install a new one on, and figure i'll hold off before putting it back on. But can't you replace the valve guides without having to remove the head? I can get access to a spring compresser for free, and damn near any other tool through a buddy at work.
Thanks in advance for reading this, and any replys i get back.
