Re: Compresion Issues, Long Post
I think my question would go better if stated like this, you can check each cylinder individually, but how? I looked at the link, and i know what your doing. Filling the cylinder up, and trying to figure out where it's leaking. If you do it through the TB, it's going into all cylinders, and will be hard to track down.
Forgive me, i'm running a temp, but i don't see how to test each cylinder individually to find out where the leak is. I'm on my way over to VFAQ right now, but i came to a very interesting discovery yesterday on my break... one i'm going to shoot myself for.
My coolant seems to be disapearing, filled it after the turbo install and it's lower then it should be. Can't see any below the cap or on the thermostat. Think when i'm feeling better i'll be filling it back up and checking for bubles. Only other thing i could think of is loose line on the turbo, but i'd smell and see the steam coming off.
I may just run over to LSE if i see no bubles though, figure it out for sure.
Edit: Following Text
Ok, i found it on VFAQ and may look into one here shortly. I'm about 80% positive it's a HG, and a guy at work has one i might be able to borrow for a few days.
