Old 10-31-2006   #2
Re: anyone have a guage to measure crank endplay?
John said you can use a feeler gauge between the thrust bearing surface and the crank. It is a bit harder, but still works.
Check both sides to make sure your bearing isn't in there cock-eyed.
John thinks (off the top of his head) that the spec is .002-.0071" Something middle of the road should be fine.
