Old 11-13-2006   #4
Re: I bet this will stump you as it does me..
Alright.
So what did you do about the cas sensor? That is different at times as well.
You'll want to swap on the 91 cas, 91 tb, 91 transistor, and then move a few pins in the ecu.
Go to http://www.dsmchips.com/1990ecu.html for more info on the ecu stuff.
I don't think it is on vfaq anymore, sorry for the bad link.
Your best bet?
Swap in the 1991 ecu (if it is a good ecu, check the caps). And also swap in the 1991 transistor, coil pack assembly, tb, and cas
