Old 11-15-2006   #7
Re: ECU and Tubo options
Originally Posted by rst95eclipse View Post
It's just me, but I wouldn't go with a "hack" style system to increase the amount of fuel your motor will see. I'm definately a supporter of DSMLink, whether it's a 9 second beast or daily driver with an upgraded turbo. If you plan on it just to be a fun car, an Evo 16g or possibly even a 50 trim would be great. But if you look into the numbers, you might as well just spend a few hundred more and get a 60 trim or a GT-30R. But of course you'll need supporting mods, so it's all based upon your goals and plans for the car.
Sorry to burst your bubble, but all the DSMLINK does is hack the factory ecu code.
The fuel adjustment is very similar as an S-afc (that is setup correctly), the only advantage is the timing control (almost).
Flaimtail- It looks like you are looking for a very basic setup (but very effective).
Injectors, fuel pump, good airflow sensor, S-afc or dsmlink or eprom tuned ecu, exhaust, 02 housing, intake, evo 16g, maybe a fmic, headstuds..your good to go.
Oh and a clutch, can't forget that.
I take it this is on a 1g? So you'll be fine with an oil feed and drain upgrade, and a 2g mas swap. I"d recommend something in the 580cc-680cc range for injectors and a street core sized fmic to go well with the 16g.
Headstuds are a must if you are going to go over 17psi, and if the motor has some mileage on it, you might as well do a timing belt and headgasket while you are there.
As far as racing is concerned, you can also use a 4 bolt rear end (91's come with a 3 bolt), and probably suspension as well.
You can also add a ported 2g manifold or an evo manifold while you are putting on the turbo.
