Thread: More Fuel....
Old 11-17-2006   #2
Re: More Fuel....
Hey everyone,
Well it is coming time to start adding more fuel.
I am looking at replacing my rewired 3S fuel pump and going with a 255lph walboro, Replacing all of my fuel rail lines with bigger ones, and putting on the Magnus 1000hp fuel rail as well as AN Fittings, and a Fuel Pressure regulator. (also will be getting a wideband, just trying to recoup after getting royally screwed)
The reason for this is because i am havinig serious knock problems above 5000 rpms, and this is the only thing i can think of that would cure it.
Current setup:
RRE 6Bolt block
RRE Stage 2 Head
2G Pistons 8.5:1
HKS Valve Springs
Ferrea Valves
DSMLink
PTE T3/T4 50 Trim Turbo
Tial 38mm External Wastegate
Ported Exhaust Manifold
Front Mount Intercooler
Magnus Intake Manifold
Custom Piping 2.5 in made by me.
Greddy Type S BOV
3/S Fuel Pump
680cc Injectors
Fidenza Flywheel
3" Turbo Back Exhaust
NGK BPR7 Spark Plugs
Magnecore Race wires
RRE Upper IC Piping
ACT 2100 Clutch
Tokico Shocks and struts
Couple questions
A: With increasing the size of the fuel lines, has any one seen this as a problem with the increased mass of fuel? I would think that either way the FPR will hold back the extra fuel.
B: Kinda relates to A. The Magnus Fuel rail is pretty big compared to stock, is this overkill for the 680cc injectors, or should i go with bigger injectors.
C: Do you think it is worth going to DSMLink V2? Or would it be better to stick with V1 until V3 comes out? (which is hopefully soon, been hearing really good things.)
D: What size fuel line should i go with? i have to find out what size my fuel rail is. Also, does anyone have a good source for Braided lines?
E: Any other advice?
A) FPR is a fpr you'll be fine.
B) You don't need the fuel rail, save your money
C) Upgrade the dsmlink
D) AN06 is plenty
E) Tune the car.
