Old 01-09-2007   #25
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Re: Kirkey racing seats. Streetable?
I rocked that same Kirkey (minus the side bolsters) in my CRX as a daily driver and did a few trips up to Bemidji (3.5-4 hours each way) with it in there. Absolutely very comfortable. The only thing I had to do for long trips was put a small amount of foam under my butt. As far as the belt, I unbolted mine from the floor and passed it through the left side hole and then bolted it back down to the floor. Then when I sat in it, I put the buckle through the right hole.
As far as the roof collapsing in a roll, the back of the seat is higher than your head. It will take a good amount of force to buckle the top. Of course mine doesn't have the large bolsters like that. That back is also a hell of a whiplash saver as well. You're probably ten or more times likely to be hit from behind then you are to roll over. And if you're rolling the car, either A: you're driving absolutely stupid, B: you slipped on ice travelling way too fast causing a spin (again, go back to A in most of these cases, but not all of course) or C: went off the road due to either high speed cornering or a freak part failure on the car. In a daily driver or a weekend crusier, you SHOULDN'T be seeing any of these possibilities except for part failure. I would, however, suggest at least a main hoop with supports if you do put the seat in seeing as it will probably be seeing some spirited driving from time to time and probably a little track time as well.
Of course I'm not saying it's out of the realm of possibilities that you could roll over in any kind of accident, just highly unlikely with normal driving.
You would be very surprised at how comfortable that seat is even with the little bit of padding it has. It holds you in all the right spots. I can't speak for the bolsters as I don't have those. I set mine up on sliders with a slight recline. Never had a complaint.
Damnit, all this talk about those seats and now I'm itching to put the CRX back together and drive it rather than sell it off like I'm trying to do.
Incidently, if I do sell it without the seat, I"ll have a seat available for those with narrow butts.
Another option is to set it up with brackets so you can take it out and put the regular seat back in whenever you want to. That way if it's used for more daily driving, you can use your original seat if you don't feel comfortable about crashing. I mean hell, it's only 4 bolts.
