Old 02-22-2007   #1
Re: alternator squeal.?
Maybe also check your Alternator fluid in case it's low.
Assuming the car is a 1G, the alternator fluid passes through the flamidation valve between the reservoir and the alternator. If there is something causing a flow restriction in the flamidation valve, the alternator could be getting starved of fluid.
