Old 06-05-2007   #12
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
Re: Winter/Wet Stability
Originally Posted by 2003eclipse View Post
jack the car up one side at a time and do a shake down test on the tires. Check for loose ball joints/ bushings. Good Luck
X2, your tie rods should have no precevable freeplay at all. could also be an issue with caster/toe. oh and those tires suck BALLS!
can you be more specific? are you having to make constant corection to keep the car straight? if you let go of the wheel does it dart off to one side?
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
