Thread: FS: 86 CRX Si
Old 06-17-2007   #1
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
FS: 86 CRX Si
It's on the block again. I need this thing gone (just like that old Snap-On toolbox I had up here a while ago).
Here are the specifics:
86 Honda CRX Si
Red
Odo shows 221,000 miles
Engine a little over 100,000 miles
Tokico HP shocks in the rear
87 Integra springs in the rear
87 Integra ECU
Home made short throw shifter with Integra linkage (short throw done the right way, not just cutting down the top)
Lowered front torsion bars
Strut tower brace front
Harness bar in the back between shock towers (Kinda bubble-gum welded in, didn't have a better stick welder at the time but it is firm)
Aluminum Kirkey racing seat on sliders driver's side
5-way harnesses for passenger and driver along with original belts as well
4 13" 85 CRX Si alloys (Enkei's that are light as a feather)
2 14" 88-89 CRX Si alloys
Random Technologies direct bolt-on replacement catalytic convertor
The Good:
The floorpan and panhard rod mount has been welded up. Body is very solid. Engine has a little over 100,000 miles. Everything works in the car.
The Bad:
The engine that was in it before shelled out. I took it out and replaced it with the one that's in it now. I am 98% done with getting the engine up and running. There is some rust in the wheel wells and a corner behind the drivers front wheel that is starting to rust. The Integra shift linkage moves the shifter forward a bit (neutral is where 1st, 3rd and 5th were). The rear brakes need complete replacing. E-brake cables are frozen up.
This would be a good project car for rallycross or autocross. Or it could be stripped down and built up as a road race car. Or it could be parted out. I just need to get it out of my garage. It is taking up space that I need very badly right now.
Looking for $500 firm.
If I think of more I will post up.
vin JHMAF5338GS026185
Here are some pics:
ID:	5806   Click image for larger version
ID:	5807   Click image for larger version
Name:	Back of seats.JPG
ID:	5809   Click image for larger version
ID:	5810   Click image for larger version
ID:	5812   Click image for larger version
Name:	Passenger side view.JPG
ID:	5813   Click image for larger version
Name:	Side view Driver's.JPG
