Old 06-18-2007   #3
Scrmegl
Brian
Scrmegl's Avatar
Danger Wheels Champion!
Drives: '98 TSI AWD
Re: Project Talon - Screaming Eagle
With things starting to change and weird sputtering when in boost I then changed direction a bit. I installed the A pillar 2 gauge pod and hooked up a 30/30 Cobalt Boost/vac gauge and a blinky O2 sensor gauge.
Then went on to change to plugs, wires, alternator. things were better but not perfect. The NGK BPR7ES seemed to work best and needed to be replaced less. I then also switched to Royal Purple oil.
Later I installed a Hallman Pro Boost controller to stop the Boost Spike problems I was having.
