Old 06-19-2007   #1
Re: Evo clutch restrictor removal is great success!
It takes like 10 minutes. Just remove your intake and there's the slave cyl. right there on the front of the tranny. Unscrew the bleeder screw, unbolt the banjo bolt from the clutch line, and then take a SMALL allen wrench or piece of wire and push the restrictor and it's spring out the bottom. Push in the direction from the bleeder side towards the banjo bolt side. reconnect banjo bolt and bleeder and you're done. Just bleed the clutch line and you're ready for launching!!!
