Old 06-26-2007   #11
x-pride
x-pride's Avatar
Re: removing the awd system from tranny
Since you look confused make sure you drain both your tranny and transfer case fluids. Yes, both. Also you will need to remove your exhuast to get your transfer case off from under neath the car. Yes the transfer case got some weight to it so when you pry if off make sure you have a jack or something to support it so it does not drop onto the ground. If you are replacing the tranny with another tranny make sure you count you splines on your tranny or your transfer case is not going to slide on.
