Thread: Compression
Old 07-26-2007   #2
Re: Compression
Originally Posted by DWs97GST View Post
When you get into boost you will build more compression. You are packing air into the cyl...
You are serious aren't you?
I guarantee that is not his issue. His static compression his low, his effective compression ratio isn't the problem. I've seen dsms run with under 90psi static.
