Thread: "V"
Old 07-31-2007   #11
Re: "v"
Beautiful! Why the flex section? Don't you have poly motor mounts?
I have Prothane inserts in the front and rear torsion mounts, but I actually shimmed the front mount (timing belt area) with additional rubber stoppers from Mitsu to limit movement which works well. Having three of those rubber stopper shims on the front side and one on the rear side is really tight. I'd just rather be safe than sorry, the flex section is not causing a restriction. It has internal webbing just like the outside so the flow is not seeing the shape of the flex section.
