Thread: PCV System
Old 08-10-2007   #17
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: PCV System
It flows both ways. Under boost, the PCV closes, and blowby and other CC leaks need a way out - through the VC breather. It helps to have vacuum to pull gasses out or they stay in the oil.
If you look at my arrangement I do have a catch can but it is sealed and hooked up back to the intake tube. So get the best of both, vacuum and something to filter out the crud that comes out the VC breather so it doesn't go into the turbo.
