Old 09-20-2007   #5
Re: EGR check engine
Is the EGR system different on 94's? every DSM (90-92) I have worked on I have always disabled the EGR systems and blocked it off with a plate. No CEL.
If your EGR system is broken, you may want to consider blocking it off with a plate.
I do not believe that any harm can come from your car with a stuck open EGR system, although a car with a stuck closed EGR system is what is desirable.
Well you'd have a massive boost leak if you have a failed egr system.
