Old 10-03-2007   #4
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: Stock EVO ECU Mods! NLTS, KnockCEL, Valet mode
"How does DSMLink to NLTS?"
Not sure if I understand your broken English?
With every purchase of DSMLink since version 2 I believe, they came with a bit of wiring that you would use to tap into the signal from the cruise clutch switch (engages as soon as you put pressure on the clutch pedal).
Then you would set up the activation triggers. Basically set at what mph you want NLTS to be activated and you then enter a "fixed" NLTS RPM say 6500.
DSMLink NLTS if you shift at 7,000 RPM your NLTS revlimiter is set to 6500 then shift RPMS try and drop to 6500, if you shift at 8,000 it trys to drop to 6500, if you shift at 5,000 it will rev up to 6500.
Evo setup NLTS if you shift at 7,000 RPM and your NLTS revlimiter adjustment is set to 1000 it will try and drop to 6,000, if you shift at 8,000 it will try and drop to 7,000, if you shift at 5,000 it will try to drop to 4,000.
T
