Old 10-24-2007   #22
Re: finally getting the car tuned
The dyno logs everything and you can look it up at anytime, I will give one to your bro if you want. Dyno settings: 4wd Center Viscous, inertia set to 80, ramp rate of 120, all corrections off, straps on the back only with a strap to hold it back so it does not pull up on the dyno, no knock showed up, NGK BPR7es plugs @.028, E-85, and 24.5psi of boost.
3rd or 4th gear? Why wouldn't you want it to pull up into the dyno? That is how you get traction on a Dyno Dynamics.
