Old 11-13-2007   #16
jhaan_dude
jhaan_dude's Avatar
Drives: a car
Re: Blowing out antifreeze
johns right, considering the stock motor makes 135 psi in the cylinders, that wouldnt work, but back to the part about the studs, did you ever retorque them????? and have you tried putting a little oil in the cylinder and done a compression check to see if you even get 135 psi per cylinder?!?
